I have a shark cat with two 90 hp fuel injection engines, both have only done 73 hours. The check light for the right side engine is on and alarm are going off as soon i turn the key, even without turning the engine on.
Before this happened the left engine cut out due to lack of fuel, immediately after this the check light and alarm came on for the right engine. The right engine was also low on fuel at the time but did not cut out at all. It starts like usual and sounds as it usually does. I have drained both of the fuel filters and flushed out the motors. There was some fishing line caught up in the prop of the left engine when we removed the boat from the water. I know that anything caught in the prop will usually cause the alarm to go off however it is not this side that has the alarm problem.
I assume the problem is minimal, does anyone have any ideas for me as to how to fix this problem or what the problem might be.
