Jerry Glenn
I have disconnected my oil tank on my 96 Mercury and am mixing the gas with oil manually at 50:1 and have a problem with rough idle and teh plugs fouling. I realize at idle the mixture should be less concentrated and the oiler compensates for that when installed, but I do not have confidence in the auto oiler due to previous bad experience. I have the idle jets set as the manual states at 1 and 1/4 turns out. Is there a different setting I can make to keep the plugs from fouling out. I have manually tried to adjust them at idle but do not really notice a difference in idle speed. Can I adjust the timing from 8 degree BTDC to improve idle?
I appreciate any ones help! Thanks
Jerry
Jerry
