90 hp Johnson
chadrok
"I have a 90 hp Johnson, J90EL
"I have a 90 hp Johnson, J90ELEOC, I don't know what year it is, but I was wondering what the correct spark plugs are. Also curious why people say not to use NGK plugs."
i used ngk on mine for a while
i used ngk on mine for a while but champions are whats rec from factory and different brand plugs have different heat ranges. when i changed plugs it seemed to idle different but couldve been just wishful thinking.
im on a different comp than normal so i dont have the site to find your year model but someone can help you from here theyll probably even give you the plug #s
What do I need to do to change
What do I need to do to change my oil injected 90HP Johnson where it will run off of mixed oil and gas?
Absolutely no need to change t
Absolutely no need to change the fuel pump! The VRO pump can be used as a " fuel only pump " by blocking off the suction line to the oil side of the pump.
"i have never had to change or
"i have never had to change or work on any vros.
i do read everything i think my brain can hold
....i ran across that info and thought myself or somebody in the future may need it.
thanks for the heads-up about not having to replace the old pump ikia!.....and thanks to everyone for the help and knowledge!!!!
im not near as green on ob troubleshooting as i used to be, still wish it was as easy as workin on cars for me though."
