90 hp Johnson Outboard fuses
McKee7
Running a 17' McKee Craft with 2004 90 hp Johnson outboard. Starter switch twisted in the console and several wires pulled off the terminals. Fixed wires. Now engine won't start. OEM manual wiring diagram shows two fuses. Repaced one located at rear of engine that was blown. Still no start.
Manual has pictures showing second fuse located at front of engine under a black plastic cover. Removed cover and found no fuse under it. Looked over the engine and don't see second fuse anywhere. Possibly beneath starter, but can't see because engine cowling obstructs view - very tight space - not a likely place for a fuse anyway. Anyone know where the second fuse is located?
Thanks for your help.
??-----Blunt question.--------Is this the 4 stroke SUZUKI built machine or the V-4 60 degree 2 stroke looper ??
