trollingbob
" Motor ony reaches 4200 rpm o
" Motor ony reaches 4200 rpm out of usuall 5400. Pulled plugs & cleaned ran fine two times out, yesterday started motor and same thing, pulled plugs and found that the top two plugs where burning perfect nice dry brown color the bottom plug was wet as if getting gas but not spark, switched plug same thing.I was thinking it might be a bad coil or wire from the coil. Any thoughts? This is three cylinder 1990 90HP. "
