90 4.3 omc shack/miss
cuzzzintn
Lets start with the first issue. Last year had boat docked and took on water around drain plug. Water got in motor. Drained motor and cousin tried to start before i got plugs out and there was water on top the pistons. Took to shop found a crack in 1 head so bought a used one and had both machined and new valves put in. Put back together and it runs great till around 2200 to 2400 rmp and then has a vibration or miss. Did a leak down test came out ok . Though a fire issue replaced cap rotor points plugs wires coil.. and rebuilt carb still same. Heard several things from diff people. Possible bent connecting rod. I figured if that would vibrate all the time. Also heard fuel issue. Im to the point i have no clue. Plus it has been at a shop for 1 1/2 months and they have no clue. Wants to pull motor this weekend and go through it just hoping to find something.. please help
