NZpackhorse
I have a 90hp 2 stroke 2005 ( 130 hours)that runs fine until I really load it up.
It seems to run fine under little load but when I load it up it will run for 10+ seconds then start to miss. If I load it up a bit more before hand then the go WOT it cuts out sooner.
I have rebuilt the fuel pump but no change.
There seems to be plenty of fuel getting to the carbs.
I have disconnect one spark plug lead at a time and then run at WOT. There was no difference regardless of what cylinder I disconnected ( except all 3 times it only ran on 2 cylinders and would not rev above 4500rpm.
At this stage I am guessing....
A. One carb is faulty, perhaps the fuel bowl is not filling up fast enough at WOT.
B. A spark plug is failing under high load/ temp
C A Coil is failing under high load.
Any suggestions?
I would rather not remove and dismantle each carb unless I have too.
Any suggestions?
