" Started motor on hose today.
" Started motor on hose today...last time run was last week in last week in Feb. when it ran fine.
Started right up as usual but idled very high, between 1800 and 2200 rpms. It would miss about every 2 seconds where it would go from 2200 to 1800rpms. Took plugs out they all looked somewhat like it was running lean. Upon further inspection I found a fuel leak in the vro oil intake, which I have plugged off...I like to premix the fuel. I will find another cap, and fix the leak...thus to my question...will that cause this eratic idle situation? It was very small leak, I only noticed it when I touched the plug when inspecting the filter and fuel lines. I assume now that I uncapped the fitting on the vro it will only drain the carbs. I put a hose on it to keep the raw fuel contained. Thanks for whatever information you can share... "
