tonysworld
This motor is running rough with a cough or sputter at WOT and at idle.. I have replaced plugs, rebuilt carb, fuel pump etc. I checked both cylinders for fire and both are working fine. Today I pulled reed valves off and there is a very small light leak thru 2 of the reeds where they close to body of valve. This motor does not seem to run at high enough rpm, but I have ordered a tach to verify. It was running great at beginning of season, but has gradually goten less power in last 3 months. It is on a 24 foot pontoon. The sputter is like popcorn popping with a nice little burst of smoke when it pops. Also, the smell of fuel is extremely strong around the motor. I can only find 1 adjustment screw on carb and have set it as I have found explained on internet/\. A manual has been orderedm but in the meantime, what should I be checking? I will order new reed valves tomorrow. However, I don't truly believe this is my primary problem. Thanks.
