My 9.9 starts and runs well but the low speed idle screw on the side of the motor cannot be adjusted to reach the linkage to prevent me from throttling to low when shifting. Seems there's not enough travel in the screw adjustment. The throttle appears to be set correctly, for example, it starts when set to start. The gear teeth on the throttle arm and motor are aligned. I would say that the carb cam follower is pretty far from the timing cam at low speed. Any ideas? Thanks Nick
