When putting motor back in neutral from forward it does not disengage while running.When motor is off it disengages fine.If I give the shift lever alittle nudge and back to neutral it will then disengage while running.Would this mean the shift rod may be a tad too long or short or something else such as brass connection block.?Connection under cowling looks good.
