Hi evryone! I have been thru most of this forum trying to find some help with an issue I'm having. Any help and info would be greatly appreciated.
I recently aquired a 79 9.9 evinrude that was to be in "excellent working order".
After intalling all new seals in the lower unit due to water intrusion I fired it up on muffs. The motor started and ran fine up to 3/4 throttle. If I hold it at 3/4 or wide open for a few minutes, it will miss and blow a puff of smoke out the exhaust and it runs out of fuel.
Squeezing the primer bulb verifies this as the motor will continue to run at full throttle.
I've rebuilt the carb and fuel pump, Installed all new fuel lines including the primer hose and still no results.
I installed a clear fuel line from the pump to carb and when I hold the throttle at full, air bubbles gradually build in the fuel line until you can eventually watch it stop flowing into the float bowl.
I did a compression test and found both cylinders to be at 45psi. I have since pulled the power head and disassembled it to install new rings, seals and gaskets. After removing the head, I could move the pistons around in the cylinders pretty easy. The cylinders look real good and actually still have some visible cross hatch in them.
Am I on the right track here or am I simply spending money on something I've overlooked??
Again......any help would be appreciated.
