9.9 evinrude four stroke
Bobrauen
This is my first posting. I have a 2000 evinrude 9.9 four stroke (e10rl4sse) I am looking for a repair for the fuel pump.
I have rebuilt the pump but the problem lies with the check valves which are not able to be replaced. I have contacted many part stores, researched online and have contacted BRP directly to find a fix. The only thing that I have found is that my pump is no longer produced and is not available. I have searched high and low to find a used one but no luck. I am wondering if anyone has a fix? it was the same pump used from 1995-2001 on all johnson/evinrude 9.9 & 15 hp four strokes. Is it possible to make a gasket for a two stroke pump and use that? it appears to be a pulse pump which may work. I dont know, I hope someone can help. Thank you
Doubt that a pulse pump will work !----------Best to see if a pump from other small 4 strokes will work.----------------Have 3 of those OMC 4 strokes and someday will look and see what the simple fix would be.
I feel like I've looked everywhere for a fix and can't find anything!
