I picked up a short driveshaft and shifter for my 9.9 Johnson longshaft off ebay to convert it to a shortshaft. It has a pretty good groove where the waterpump seal rides. The seal "seems" to be good on the shaft but not sure if it will be a problem? Should I go ahead and just put a new seal in the housing or is it a big concern if water does get past? It is a older motor, a 1977 so it does have the o ring at the top of the driveshaft to help seal or I think thats its purpose. Surprised to see a groove wore in there from a rubber seal! A new driveshaft when they can be found is over 200 is why I went used. Motor is all back together and seems fine. Thanks for any thoughts on this. Jim
