9.5 water spray
CraigChism
Help!
i acquired what I think is a 69 9.5 evinrude. Cleaned carb, new fuel pump, starts on 2/3 pulls. Runs fine. Water pump is working. However, I have a rather high pressure water spray from under the flywheel towards the pull start, I thought it was a bad ‘post’ exhaust water jacket gasket leak, took it apart and silicone gasket on the first 2 layers. But it’s still there. I can’t imagine it’s a cracked block since it isles smooth and revs fine in neutral. It fear it pulls normal. But there’s an awful lot of water spraying towards that recoil. Any ideas?????
#50 gasket missing?
Hi all, I have a problem with the motor. From the engine compartment is a little white smoke, because of this in the cabin is a very unpleasant smell, the whole house stinks of a specific perfume, the boat master has repaired, but the smell remained and did not want to get rid of, have tried and different fresheners and remedies until I came across the smoke odor eliminator spray. I thought, let me try to order, and then breathe was already impossible. I called and tried it in the case; while the smell is not felt, I hope it will not appear again, or I have to sell it.
