"My friend just bought a 89
"My friend just bought a 89' 25hp Johnson electric start outboard. We hooked it up to a battery and fuel tank, replaced the spark plugs and gave it a crank. Initally fuel was running out of the carb vent (Stuck Float) but the engine would fire right up if you hit it w/a squirt of starting fluid. We removed the carb (after removing the starter to gain access to one of the nuts). Just as suspected the carb bowl was sludged up and the float was stuck. We cleaned it out and re-installed it and the starter. The fuel leak was stopped but now the motor will not do anything but backfire. We did not mess with the flywheel or timing. We put all of the wires and linkage back like we found it. Does anyone have any ideas? I have always done my own work on small engines 2 & 4 stroke but my experience with outboards is very limited.
Any help would be appreciated.
Steve"
Steve"
