89 Merc black max xr4
gizmoi
i rebuilt carbs thinking this
i rebuilt carbs thinking this would help motor idle better in no wake zone it didnt help i am going to rebuild fuel pump can you think of anything else?
replaced inlet and seats clean
replaced inlet and seats cleaned the rest seloc said only time main and idle need replaced is if my sea level was to change
Or if they are distorted. The
Or if they are distorted. The needles do wear and need to be replaced if they are not in pristine shape...
Your motor is really 6 seperat
Your motor is really 6 seperate motors with a common block and crankshaft.So you need to check compression and spark at each cylinder MUST jump a gap of 7/16" or better.You could easily be running on 5 cylinders!
