89 MERC 15 HP Pilot Assist Function
archibaldg
"Can anybody tell me where the
"Can anybody tell me where the pilot assist screw is on my 1989 (probably) 15 hp Mercury outboard? I have the manual (1989 Brunswick Corp)and there is a weak illustration on page 10, item 7. Is it port-side, starboard side? Thanks for any help you can give."
"Greg, to put aside the someti
"Greg, to put aside the sometimes confusing port/starboard
Should be on the right hand side as you are looking at the front of the motor (carb end)..."
"Graham,
Thanks for this.
"Graham,
Thanks for this. I'll have a look-see. I actually think I know the screw but found it kinda half-hidden behind something that made it hard to get a screwdriver on it, and then I couldn't get more than a quarter turn clockwise which didn't tighten the steering at all. I will try again. thanks for your interest."
"Yes, it's kinda in a dimp
"Yes, it's kinda in a dimple right behind the reverse locking mechanism.
That screw presses on a very small metal plate which then presses on a (kinda plastic) bushing.
The bushing often cracks and the little plate slips a bit making the whole thing quite ineffective (and a major pain in the butt to change out).
If you pull the screw (bolt) out and replace it with one just a touch longer (from any hardware store) you can restore some of it's function."
