budsterjames
I was traveling 30 mph when I lost forward gear and reverse. We started messing around and took the prop and lower unit off, it seems like when you play with the shifting rod and put it into gear, if you play with it, it will catch but typically there is no resistance you can spin the propeller shaft. Any ideas? We didn't over heat or anything, just stopped moving and were full throttle, killed the motor and got towed in. Thanks for the help.
