hitech_redneck
"I have a 1989 Johnson 175gt m
"I have a 1989 Johnson 175gt motor that seems to have an appetite for power packs.
This first started out after I rebuilt the blown powerhead due to a cut lower crank seal causing #6 to seize & exploded bits & pieces of piston & rings into # 5, after running more than 40-50 hours on the new rebuild I noticed that it was getting hard to start after setting unused for a couple of weeks.
I knew the reg/rec was inop so I went ahead and purchased a new power pack and reg/rec.
Since I’ve installed the new electronic components I haven’t used the boat that much, 1-2 times every few months.
I was headin’ to the lake last week and tried to start the motor & run it on a flush kit to make sure I burnt all of the storage oil out of the motor & make sure it was going to run ok.
Well it wouldn’t start, I checked for spark with 6 new plugs & with the old ones out of the heads & I had nothing, I went ahead & tested the ignition switch & emergency kill switch, no problems found here.
I disconnected the main wire harness connector & spun the motor with a remote starter switch on the solenoid, still no spark.
I reconnected the main harness connector & took a 30 min break.
When I came back I turned the key a noticed I had spark on Cyl #1 but not on the other 5.
I reinstalled the plugs on cyl # 1&2 and was able to get the motor to fire on that 1 cyl, after running for less than 1 minute like this I was able tell that it was beginning to run on #2 as well, also & I had spark on the other 4 plugs when #2 kicked in.
I installed the rest of the plugs and ran it on the flush kit to check it out.
Everything checked out ok.
3 days later I head to the lake and it runs like it should, no problems at all.
A week goes by and I decide to head out again, I fire the motor up at the house again, cranks & runs.
When I get to the lake, a 45 minute drive, it wont start, no spark again, so I come back home.
A few days later I go out to check to see what’s up with this thing & I double check everything again, I even unplug all electrical connectors & check for corrosion on the terminal pins, nothing found. I give up, go inside & look for my shop manual that has disappeared for some reason; of course I haven’t found it yet.
The next evening, yesterday, I go out spin the motor with the key & I can see it’s firing on #1 again so I do the same thing again with cyl # 1&2, again it fires up on #1 & a few seconds later it starts running on # 2 & simultaneously it starts firing on 3-6 too.
Today it’s starting & running on all 6 again.
Now it did this with the previous power pack except for the one cylinder that would get fire was # 6, & I could do the 2 lower cylinders & it would run out just fine, then every once in awhile it do this same thing again, then I didn’t feel comfortable going out on the lake like this so I bought new reg/rec & I went ahead & replaced the power pack, while I had an extra $600.00
Now this new power pack doesn’t have 4-5 hours on it.
When I had the flywheel, stator, & pick-up coils off I inspected them & they looked fine.
No bubbling in the epoxy or melted or burnt wires, & the magnets are fine.
I need help with finding what is killing power packs so I can fix it, I can't afford $300.00 for a new power pack every time I decide to go fishin' & fuel too, is there something else I’m overlookin’ or don't know about.
Anyone please help, Sometimes-Sparkless"
