89 Johnson 150
geoff
" My tach doesn't work, an
" My tach doesn't work, and my charging system doesnt seem to work. Is this most likely my regulator/rectifier? "
"Gray wire leading from engine
"Gray wire leading from engine wiring harness to terminal block is tach sensor wire. Other gray wire at that terminal leads to regulator/rectifier.
Move the engine harness gray (tach) wire to the stator Yellow/Gray wire. If tach now works, the regulator/rectifier is faulty.
If there is only Yellow stator wires (no yellow/gray), connect to one yellow lead, then the other for the test.
Joe
