J
Jeff forsyth
Guest
Just replaced water pump and p
Just replaced water pump and prop shaft seals. Put this motor back together and started it and let it run for 20 minutes or so. Runs great. Problem is I noticed some brownish grey oily stuff dripping from the skag. Took the prop off and it was running out from from behind the prop housing .Is it possible the seals under the water pump are shot? Checked the lower unit oil and it had no water in it. Thxs in advance for the help!!!! jeff f
