89 Evinrude 88 hp Powerhead removal
tex14
Trying to remove the powerhead
Trying to remove the powerhead and it's stuck. I have the OMC repair manual and have followed it step by step. The front comes loose but the rear by the theromstat housing is stuck. Not sure what else to try without breaking anything. The lowergear case has already been removed and I can't see any bolts that might be holding it on. Help.......
"It's common for the two r
"It's common for the two rear studs to be corroded tightly within the retaining holes that they pass thru. That becomes a job requiring patience, peretrating oil, whatever, prying upwards on the studs etc.
NOTE.... DO NOT attempt to insert anything between the powerhead and the adapter plate to pry in that area!
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
Yep I got both of the back two
Yep I got both of the back two nuts off. I guess I'll just keep spraying WD-40 and peretrating oil. Any other tips that may get it to come loose.
"first,....make SURE...u have
"first,....make SURE...u have all bolts and nuts off....2 nuts on fr and 2 at rear,and all the bolts,....if u have a lift,to put some upward pressure on the pwrhd that will help,...also,...standing on one side,...forcefully,try to wiggle pwrhd,fr sd to sd....put a nut back on one of the rear bolts,and pry up,on it...."
"My dad is almost deaf and did
"My dad is almost deaf and didn't hear the over-temp warning horn. Burnt the port top piston, so I'm doing a compete rebuild of the powerhead and everything else except the gear case."
"I've found that a hand he
"I've found that a hand held propane torch, directing a hot flame at the aluminum surrounding those studs will help in freeing them. Just have a fire extingusher and a garden hose handy just in case.
Good idea to have the hose turned on (grin).
I'll try the torch and a g
I'll try the torch and a garden hose (water Running); I've tried everything at this point. If anyone else has any new and fresh ideas please let me know.
"Yep, the front is loose but t
"Yep, the front is loose but the rear is stuck. Those two rear studs will'nt come loose. I'm going to try the torch method in just a little while."
"remember,it needs to come up,
"remember,it needs to come up,..evenly,or u will get those bolts in a bind,and lift the whole boat!."
