The engine appears to run strong but no water was coming out of the tail tell.
1. I replaced the water pump and confirmed it is pumping via a drill with and the lower unit submerged in a drum.
2. I also removed the thermostat and cover. I used a water hose to send water up to the engine with plenty of water flow out of the tail tell and thermostat port with the engine off.
3. With the lower unit on the engine and submerged in a drum over the water pump level, I see exhaust smoke come from the thermostat and tail tell ports but no water when the engine is running.
Question:
1. Does anybody know what the problem is?
2. Is it possible that the internal exhaust is causing enough pressure in the water passages to not allow the water to get all the way to the engine?
Question:
