89 90hp rude changing t stats
sticky
"hi all,looking at diagram in
"hi all,looking at diagram in manual,it is showing springs and cork gaskets going into powerhead adapter first,i thought you slide corks down on t stats,input please,thanx yall"
"<[img]"http://www.marineengin
288943.png"" alt=""
"it shows thermo in spacer the
"it shows thermo in spacer then cork then gasket.
i think i had the same problem when i did mine .
i ended up putting the cork in the spacer then thermo/gasket,the older kit that was in prior had rubber seals that fit around the thermo forming a seal at the spacer and gasket."
