89 70 hp not charging properly
ntmdave
I have a 70 hp not charging properly.. replaced lighting coil and rectifer but still only getting 10 volt at idle.. could the magnets on flywheel be going bad/ weak...
I can't think of what else it might be if the lighting coil and the rectifier/regulator are working properly.
Have you tested the lighting coil for proper voltage to the rectifier/regulator?
