89 45hp classic fifty
Michael LaSalle
I have a 89 mercury 45hp classic fifty that is only running on three cylinders.
I have just went through the whole fuel system with all new everything. New spark plugs. Compression checks out at 125. It starts right up an goes ab 18-20 mph in the water, but seems to not quite reach 5000rpm. It seems a little gutless. I got home an checked the spark plugs an the bottom cylinder plug is still new looking while the other three are a normal browned/black. #4 is lightly wet with oil, so i know its getting fuel.
So i switched the number 3 and 4 cylinder plug, wire and coil and ran it again. Still no fire on bottom #4 cylinder. Funny thing is that cylinder shows a spark when using a spark checker
Something is causing it to get a weak or intermittent spark on that bottom cylinder or causing it to not get spark under load. What do yall think
Perhaps the bottom crankshaft seals are blown and you have no crankcase compression on #4 cylinder.----Or perhaps there is a problem with reed valves for #4 cylinder.-------Is this something that happened suddenly or developed slowly over time ?
