89 225 Evinrude Nutral switch
friday280
"Hello,I have 89 225 evinrude.
"Hello,I have 89 225 evinrude.The problem that I have is the boat is running in nutral idels perfect. I put it in foward works fine then when i shift from foward to revers and stop on nutral egine shuts off.I have to put the shifter back on nutral turn on engin and then hit revers and will not shut off.A mechanic told me that it was the nutral switch that is located on the engin under the foward and revers linkage.Is thier a way of testing that switch to make sure is that?"
"sounds like u r idling too sl
"sounds like u r idling too slow to me...your ns sw,is not......affecting running of eng.....find another mech."
"after re-reading your post,..
"after re-reading your post,..what u r referring to,is a shift switch,NOT N safety sw..what do u mean,it wont 'shut-off'."
I would suggest to adjust the
I would suggest to adjust the shift cable and lubricate the switch to be sure it operates as intended. It might even be a case of shift cable going 'bad'. The cable need a small 'play' in order to make the SHIFT INTERRUP SWITC operate as intended. Be sure the engine operates on all cylinders when engaged forward or reverse befor adjusting idle.
You are right jw its called a
You are right jw its called a shift switch my bad.What I mean is when I turn the engine on in nutrual and go reverse the engine dosent shut off it stays on .The problem is from reverse to nutral to foward then the engine turns off. I have to place it in nutral turn engine on then go foward.Morten I will check for play.Yes the engine reuns great and Idels perfect.
"why do you want the engine to
"why do you want the engine to shut OFF,when u go to reverse.....i'm lost!!!!..if u mean u cant turn the engine OFF at all w/the ign sw...then that system needs to be checked...may be a bad ign switch,loose/damage kill wires."
"No,I do not want the engine t
"No,I do not want the engine to shut off.I have the shifter in foward and I want to go revers.From foward i have to put shifter in nutral then revers thats when the engine shuts off.Then I have to put it back in nutral and start the engine then go revers."
"it is very poss your shift sw
"it is very poss your shift sw is bad/or causing prob's.lube it,or disc and try.it helps u shift OUT of gears,if it hangs,or is bad,it kills 3 cyls,and is maybe not releasing."
They had told me to disc sw an
They had told me to disc sw and see if it was still doing it.Is that the only way of cheking the sw? jw once I disc the sw and it still doing the same could it be the switch then? Thank you
"nope,if u disc sw,..and it st
"nope,if u disc sw,..and it still does it,..then your engine needs to be evaluated,to determine your problem."
"Is that the only way of cheki
"Is that the only way of cheking the sw? no---ck it w/an ohmmeter.
the eng,will 'turn-on' as always."
"I got the feeling You are mes
"I got the feeling You are messing up a couple of things.
The engine have 2 switches:
1: No start in gear switch in the remote control. This prevents starting the engine if the lever is in forward or reverse: this why You have to go to neutral to restart.
2: Shift interrupt switch on the shift mechanism on engine. This cuts out one bank of cylinders when a certain load is put on the mechanism. Normally it will only engage when shifting OUT of gear, providing the mechanism , lever, bushings etc are properly lubed. Out of gear it easies the force needed to disengage the clutch dog from forward/reverse gear due to a negative cut in the lugs. If gear cable is not correctly adjusted, shift-stroke is wrong,++++ the switch may be engaged and cutting 3 cylinders whichever gear You shift into or out of.
Try to disconnect the cable from the engine and shift by hand directly on the lever. If everything works, get the cable adjusted properly and check the shift cable travel from remote. If cable is sticking, change it."
