Recently at sand bar and shortly after the impeller keyway broke and no water was peeing. The alarm went off and I shut it down and towed it in. I installed new impeller kit, housing, t-stats and poppet valve. The engine still sets off the alarm and the temp goes to aprox,150 degrees. The heads feel really hot and the now when you crank there is no water coming from the pee hole. Prior to this it had a good steam during cranking. Also after the alarm goes off and it cools down there is no flow from pee hole again. I took back apart and all looks good. Could there be some blockage at the copper feed line coming out of the pump ?? Is there a back flow test we can do also to check the water flow from the poppet valve. Please help.. Rick
