"I recently purchased a used 1
"I recently purchased a used 1994 88hp Johnson motor before my first trip the compression was about 125 psi 3 cylinders and one was about 120, however after first trip I burned about 75 gallons of fuel and returned with a compression of 120 psi 3 cylinders and 190 on the one. The engine appears not to have a cooling problem is this problem.
When I bring the motor in a elevation of 3,800 the spark plugs run a little rich and the when I punch it has allot of hesitation, when I put new plugs in it works good for a while, however it does not take long before the hesitation returns. Other changing the jets in the carb is their a plug you would recommend, I’m presently using a NGK standard plug."
