88b DT150 Ignition timing switch and red rubber pushbutton
"Hi All
On this outboard of m
"Hi All
On this outboard of mine there is an ignition timing switch located on the electronics panel on the side of the block which you can set at different positions. What do you do with it? Also, located directly below it, is a red rubber push button which I have no idea what it does......?"
"Oh ok, excellent.
Thankyou
"Oh ok, excellent.
Thankyou for that. So will the engine run with the switch in any position? I use it as a ski motor, is there specific setting for this purpose?"
