88b 115HP EFI Lower Unit assembly
a1nowell
I have reassembled most of the
I have reassembled most of the lower unit. I am having trouble installing the bearing carrier into the housing because of the new O ring. Any suggestions??
"Hey, grease the o-ring and do
"Hey, grease the o-ring and dont be shy putting it in, you will need to use some force to get it in there.
May I ask what all you replaced when you were "rebuilding your lower unit"???"
"How do you keep the O ring in
"How do you keep the O ring in the groove while forcing it into the housing? All I replaced was seals, O rings and rebuilt the water pump. All the bearing looked OK. Did I miss sumething? "
"-Hey, I was just making sure
"-Hey, I was just making sure you didnt put new gears/bearings in (of course you would have to shim in that case). Aslong as you got your shims back in the right place you'll be good to go.
-Now the problem with the o-ring sliding, some man"
