"Hi I have a 88 sunray with a
"Hi I have a 88 sunray with a GM 5.0L and OMC Cobra, I have removed the aluminum 14.5X19P prop. I bought the same size prop on ebay except its stainless steel. Its not a high $$ performance style but looks more like an o.e version the number on it is 389924. My question is will it work with my outdrive? It has the same number of splines (15) but it is significantly heavier. Does the weight matter, can the shaft support it? Also when I put it on (with the spacer that was on my old one) it rubs the case. Do I need a thicker spacer? Any input would be greatly appreciated
I dont want to break anything, Thanks"
