"I have a 1988 OMC COBRA 3.0L.
"I have a 1988 OMC COBRA 3.0L.Started having a problem shifting to neutral.Checked the interrupt switch OK,check the overstroke OK.I have ESA module on order,should corect the problem.OMC dealer told me that he is gettig me upgraded ESA that only works with points,since I wanted to go with electronic ignition.
I owned the boat for five years and never had shifting cables adjusted.Removed the outdrive,checked the height on shift rod OK.Shifts forward and reverse OK.Now I am redy to adjust all the cables.Found good info from Stuart Hastings but pictures are wery dark and and info is little confusing(probably only to me).Any help maybe a picture would be appreciated."
