88 hp evinrude water pump removal
coach_j
"ok i know these things can be
"ok i know these things can be a little hard to remove, but i cant seem to get this thing to move a hair, just how much force is to much"
"it's a 1993 evinrude, i
"it's a 1993 evinrude, i cant seem to get the impeller to slide up off the shaft to replace it"
"Normally, placing a large pun
"Normally, placing a large punch, chisel, block of wood, something, between the impeller blades, then hitting it with a good size hammer breaks that impeller loose from the plastic retaining key and driveshaft.
If not, then you'll need to cut away a portion of the rubber impeller and split the impeller hub with a chisel.
Thousands of parts in my remaining stock. Not able to list them all. Let me know what you need and I'll look it up for you. Visit my eBay store at:
