Thanks for the input, Jerry, as always...
Now that I've had some time to think about it, duh, the power lead should not be direct from the battery. When the engine is running, it is CHARGING the battery at more than 12volts. That would make the gas gauge max out, right?
So the power to the gauges should probably be coming from the throttle control box, correct? You say the purple lead?
Right now the power from the battery goes to a switch on the dash that turns on the gauges. Its screwy because the motor change from 90 to 125 was done by a rookie. The thing that threw him for a loop probably was that the ignition key for the 90 was on the dash. The ignition key to the 125 is on the throttle control. So wires got cut, re-arranged, and spliced.
Under the dash, I can see where the power wire to the gauge cluster comes in from the battery. Should I change it from the battery terminal, to the purple lead inside the throttle control? I assume that must be some kind of regulated power, right?
Is there a volt regulator on these Forces? Is it the rectifier? Is my rectifier bad?
