Blasterdukes
I picked up an 88 Evinrude 110 VRO for a project boat i have been working on. The original 90 melted down a piston and a co-worker offered me this 110 to replace it with but he said he thinks it has some sort of fuel issue. He explained to me that it will start up fine and run slow alright for 5 or 10 minutes but then would begin running rough and eventually stall out. However, if you ran it fast it will run fine all day, but as soon as you slow down to idle it would stall. After letting it sit for a few minutes or so, it would start up again but didnt want to idle.
So when i got it, I cleaned the carbs thoroughly (fairly built up with excess oil) and gave it a compression test (all near 120). Plugs were good and lots of spark. Installed it on the boat and it fired right up and ran smooth on muffs.
Launched the boat and it started fine at the dock, idled around for a bit, then exercised the throttle a bit and it was running very well. Threw a line out and started trolling and soon after it stalled. Got it started after a bit of cranking and the high idle on, but it didnt want to idle without the fast idle engaged. Managed to get moving again and opened it up and it ran flawless. Lost my hat so turned around to go rescue it and it stalled again. Never got it going again (or retreived my hat), returned on the kicker.
Fast forward after 3 days of sitting on the trailer, put the muffs on it turn the key and it sprung to life like nothing ever happened.
Does this sound like a fueling issue or electrical, or maybe a combination of both? I am trying to tackle this systematically so im wondering what the best place would be to start. Thanks in advance.
This is personal now since my favorite hat is now lost at sea...
