Hi guys I have pulled my boat out of storage after 12 mths. I replaced the impella as I do every year put LU back on and found I only have forward? Pulled the LU off again and with vies grips turned the shift shaft CCW and find neutral turn CW and only have forward till I get neutral agian? Seems there is neutral at the end of each turn but only forward in between? As it has been sitting for 12mths is it possible the shifter spring is just stuck or could it be the cam? Motor had a full rebuild only 45hrs ago and gear oil is clean. Any suggestions. Thanks Andrew
