My shifter will not go all the way into fw or rv. I have removed the outdrive and cleaned built up corrosion behind the shifter linkage. I have removed the shifter and checked for obvious problems and I have tried to make ajustments to the shifter cable. All with no positive results. The cable does not seem to be frozen, but it simply will not travel the full distance either way to engage the gears with out tapping on the linkage to make it complete the travel. What do you suggest.
