87 omc cobra 4.3
Jtaylor28752
Hey, as stated I have an omc cobra 4.3. Ive been working on it trying to get it ready for the water. After changing the impeller and trying to get it to run for a few mins i found out my power steering oil cooler broke the end cap off. Was wondering if anyone had any luck trying to weld it back on or just better off buying a new one? Thanks in advance
Ayuh,....... You didn't drain/ winterize it, it froze, 'n blew out,......
It's soldered together,..... Pull it out, refit the piece, 'n sweat it back together,.....
Gonna see if i can get a picture to load. I had this piece stuck in the exhaust bellow on the foot side, anyone know what it is or where it came from
Looks like a flapper (shutter) burnt up from a bad overheat. When that happens you should also replace the water tube grommets because they may be burnt up as well.
