"Hey guys,
Please provide som
"Hey guys,
Please provide some of that incredible insight and wisdom you all have to help me solve my problem. I had a Pertronix Ignitor installed last fall and didn't change out the coil. This past weekend the engine cranked but wouldn't start. I found that I wasn't getting any spark so I started trouble shooting the ignition and found no spark at the coil. In the process of checking for spark I ruined one of the plug wires so I replaced all of those.
Today I received and installed the Pertronix Flame thrower used with the Ignitor(3 Ohm coil). When I installed the coil I left off the resistor wire from the choke and the purple w/ yellow stripe coming from the solenoid and jumpered from the solenoid(P/Y stud) to the coil + and the engine fired right up and ran flawlessly for 5-10 mins until I shut it down. Having declared victory I cut the purple resistor wire where it and the purple/yellow wire are joined at the ring term on the coil + and just attached the purple/yellow to the coil. When I tried to start the engine it fires and starts but it immediately dies. I don't have a fuel problem cause I can smell that and when I took the purple/yellow wire off the coil + and went back to the jumper wire that worked originally that wouldn't work either. Same result.
Please provide me some ideas for solving this problem if you have them. I put a call in to Pertronix but didn't hear back as of yet so I will talk with them tomorrow. Is this something obvious I'm overlooking or does this sound like a problem with the Ignitor itself? I did check the coil for spark and have good spark coming from it. The coil is mounted horizontally and is the epoxy model instead of oil. Should this cause any issues?
The engine again is the 1987 version of the 470. MCM 180 3.7 LX inline 4 with closed cooling.
Thanks for any and all help you can provide. It will be much appreciated."
Please provide som
"Hey guys,
