Have a 2 cylinder 50 hp Johnson that was having some issues with dropping a cylinder and not able to get on plane. Since, have checked compression, both good at 145. Good Spark. Replaced both ignition coils, plugs and wires, power pack, timer and charge coil. Also, have taken apart the carbs and clean both. We are now running on both cylinders and able to get on plane running at close to our old speed. The problem is the low end, when we first hit the throttle it does not get up and go quite like it did before. We still do not have the power we used to on the low end. Not sure if it is a timing issue(since the flywheel was removed), or if it could be a fuel issue. If the butterflies in the carbs are opened up all the way, it runs great at WOT, but will not idle(constant backfire and missing to the point it just conks out). Please Help, would like to get back to rippin lips!!!
