'87 johnson 8 hp
dimitrimfogal
hey guys , is there online manuals to download for this engine?...thanx...mine is stuck in forward gear and i need to fix it but dont have the manual.....dimitri
The shift system is different than what most are used to.-------------------Just take the bearing housing out the back and inspect the internals.--------------------When I looked at the first one Of those I said -------" what is this " then after looking at the parts it was an easy fix.--------------------Drive balls are broken I think.
I had a 6 HP 89' with the same trouble. Drive balls were sheared.
It may be difficult to get the prop shaft out.
I put a screwdriver through the hole in the prop shaft and hammered in the stern direction.
Once you get it out it was an easy fix. I resealed everything. There was no other damage.
thanx for the help guys . as i was looking for a manual i discovered that this engine is a '94 not an '87 lol i just bought it so im still learning about it...im gonna pull the prop assy out the back and inspect...thx...dimitri
