"I have a problem when i run a
"I have a problem when i run at 1/2 - full throttle the motor sounds like it has a bad miss. but only intermitent, it will run out for a few hundred yards then it starts for a second or two then runs ok for another little bit and does it again and so on , the longer i hold it open the worse it gets at an idle it seems ok, I have had the carb rebuilt and new plugs put in as well as a fresh tank of fuel to no avail. any suggestions Fuel pump maybe ? Coil ? Timing ? dont know where to go from here.Any help would be very appreciated.
Regards Ken"
Regards Ken"
