R
rage
Guest
"We get a good steady stream w
"We get a good steady stream when we start the engine but when we travel at headway speed the cooling water starts to heat up then steam blows out the telltale. Shut it down for a few seconds and restart and the steady stream of cool water returns then heats up and starts to steam. The high temp alarm isn't sounding but we didn't run it with the steam for very long. The initial steady stream seems to indicate the water pump is okay. If figured it was the thermostats but the manual says they usually fail open. Any ideas? Shouldn't that temp alarm be sounding if we've got steam? How do you know if the engine is really overheating? Thanks,"
