downtradden
I have a force 125 outboard, on a bayliner 18 fishing boat. this is my first real boat and I bought it about three weeks ago. first trip out it ran fantastic, just had to adjust carb slightly to keep idling. second trip out it was running great, ran out of gas, put gas and oil in it and it started right up but would no longer go into forward,motor would rev up, water bubbled and sprayed all over but we went no where. propeller seems to spin free in neutral and engages in forward, but only spins a very little bit even with engine running high. there is a slight clicking noise as the motor idles down but it is not coming from engine itself. also when it is running it dies almost immediately when you try and put it in reverse. almost as if the shaft locks up. any suggestions as to what this might be, simple or complex. like i said first boat and don't know where to even start.
