87 Evinrude 90
stevenz
"Just got alarm fixed - new be
"Just got alarm fixed - new beeper installed,
1st turn - no noise
2nd stage - continual beep
3rd stage engine start
key sticky but when I come back to 2nd stage get a
intermitant beep a few seconds apart with engine running.
Alarm fixed and fitted by mech.
Have sprayed WD 40 in key lock to free as very sticky, alarm beep is very close together, oil res full. Any ideas."
"Don't play with that faul
"Don't play with that faulty ignition switch. It may throw voltage to areas where it does not belong. Install a new switch.
Make sure that the voltage lead to the warning horn comes from the "A" terminal of the ignition switch. The warning horn has two terminals and one built in black ground wire. Make sure that the TAN wire is attached to the terminal closest to that black ground wire, otherwise weird happenings will occur."
"Thanks Joe, Will have a look
"Thanks Joe, Will have a look this weekend,
by the way talked to you a while ago about no spark on one side, turned out to be a faulty power pack that had been installed."
