dreamchaser
"I have a 87 Campion Delta 150
"I have a 87 Campion Delta 150 14ft bowrider with a 60 hp 87 evinrude elec tilt motor that I recently bought(as is $1500 with trailer) and have been with Graham Lamb's help prepareing for the water. Compression is 119,120,121, spark is strong, removed the VRO and have a new impeller ordered, but as I was testing the motor I discovered the steering cable ( worm gear type) siezed
and as I was removing it I discovered that I could not fully withdraw the control end from the engine pivot. The hole in the bulkhead that the cable comes from the front of the boat is offset from the motot pivot. there is not enough clearance to fully pull it out before it contacts the bulkhead. So.......my questions are
1. the VRO has a black,white,tan,and purple wire coming from it.Which do I disconnect to stop the oil low alarm?
2.Do I have to lift the motor off to remove the steering cable and,
3. is there a way to un sieze the cable
Sorry for the long post and I know the steering cable is not a motor question but this site has some knowledgable people on it so.....
