"hi everyone, first post...i h
"hi everyone, first post...i have an issue with my 87 evinrude 50 vro. the first time i ran this motor this year i got an overheat alarm. immediately i replaced the water pump and thermostat. flushed the water line when i did this. i'm still getting the overheat horn after aout five minutes of idling. the motor starts and runs great, and it doens't even feel that hot...i can touch the head or the block for three seconds or so before it burns...i was told by a tech that this is normal. also the pee stream is cool to lukewarm. it is my understanding that the tstat should open at 140, meaning it would idle at just over this temp...and the temp sensor or sending unit would trigger the alarm at something like 200....theres no way its that hot, this would burn like heck the minute i touched anything and the pee stream would be hot as well...just a bit over 200 and there'd be steam....can any of you guys think of another possible issue...my next guess would be a bad temp sensor...am i on the right track, or should i look elsewhere...i should also mention that i do not have a factory manual yet...just orered it from kencook.com so its wont arrive for a while yet...how can i test the temp sensor for proper function to see if this really is the issue?"
