87 DT40
compys
"Hello, I'm a new member.
"Hello, I'm a new member. My engine is not pumpig water and I'm going to check the impeller and it's housing. Can anyone tell me how the change shaft is released. It appears to be buried under the engine and requires dissassembly of the oil tank and air cleaner at a minimum to access it. Or can the shaft be released once the lower unit is dropped slightly ?
Marty (New Zealand)"
"Hello,
I also have an 87 DT4
"Hello,
I also have an 87 DT40 with different problems, see my post.
The water pump sits on top of the gearbox.
First you need to release the gear selection which is an in line nut situated at the back just below the lower engine mount. Then undo and remove the 6 bolts that hold the gearbox on, then lower and remove the gearbox. Note that the engine will need to be tilted as the driveshaft is attached to the gearbox. The water pump is located on top of the gearbox."
Thanks Martin A good look re
Thanks Martin A good look revealed the release point. New impellor fitted and we're fishing ! Marty
"I'm looking for a few ans
"I'm looking for a few answers I have a Suzuki Dt40 1988 I'm not getting any water pumping out, but I read the manual and it said that there is a minimum temperature for water to pump, but I'm scared to run it to long and hurt my engine, could you tell me if yours immediatly starts pumping water or how long it takes"
"Chris,
My DT40 will pump wat
"Chris,
My DT40 will pump water from cold, knowing my luck this is probably a fault as well.
Check the water pump as described above. Also what I have not yet done is check the thermostat. Not sure where it is though.
Cheers,
Martin."
